Nyirishman1877
May 24, 2017Aspirant
Orbi WiFi System
I would like to know if the satelite needs to be hard wired to a device to receive singal or will it just send the wifi signal with just being plugged in and wireless linked to the orbi mother router...
- Jun 04, 2017
hi
the router must be in the middle of the two sats as the orbi currently only works in a star topology
so would have to be
sat -----------router ----------- sat
pete
peteytesting
Jun 05, 2017Hero
indeed the orbi router and sat is far better than a r7000 wifi coverage wise
Nyirishman1877
Jun 14, 2017Aspirant
I understand that there is a light and glow on top of the sat and router can that light be turned off or does it always stay on
- peteytestingJun 14, 2017Hero
omce started up and everything is working as it should the lights go out and only light up if omething is wrong
- Nyirishman1877Jun 26, 2017Aspirant
One last thing before i decide to purchase the product. If there ever is an outage and the power comes back on. will the orbi router and satellite connect with no issue as it did during intial setup?
- peteytestingJun 26, 2017Hero
yes if the power drops and comes back on the orbi system will startup and connect again , the lights do come on at this time for about a minute till the system reconnects and then they go blue and turn off
