Paiatz
Jun 07, 2017Guide
Orbi WiFi System
Hello all, i have a ORBI RBK50 system and i want to connect Reolink Argus Wire-Free Cam´s to it. This Cameras are working only with 2.4 mHz. Why is this not possible ? regard R.Pojeti
- Jun 07, 2017
Try unchecking "Enable 20/40 MHz Coexistence" under Advanced, Advanced Setup, Wireless Settings, in the Orbi GUI.
There's a chance that might allow your 2.4 GHz device to connect.
shwnwllms
Jun 07, 2017Tutor
You might also try turning on the Guest Network if that doesn't work, I had a 2.4 Ghz device that wouldn't connect via the regular 2.4 Ghz channel but had no problem on the Guest Network.
