Paiatz
Jun 06, 2017Guide
Orbi WiFi System
Hello all, i have a ORBI RBK50 system and i want to connect Reolink Argus Wire-Free Cam´s to it. This Cameras are working only with 2.4 mHz. Why is this not possible ? regard R.Pojeti
- Jun 07, 2017
Try unchecking "Enable 20/40 MHz Coexistence" under Advanced, Advanced Setup, Wireless Settings, in the Orbi GUI.
There's a chance that might allow your 2.4 GHz device to connect.
Paiatz
Jul 04, 2017Guide
after electricity issue i lost the connection to my cam´s (2,4 GHz) i tryed to check and uncheck "Enable 20/40 MHz Coexistence" but nothing helps. the CAM´s are niot able to find the ORBI Wlan..any suggestions what i can do ??
st_shaw
Jul 04, 2017Master
I suspect the problem is related to the latest firmware. I can no longer connect to one 2.4G device that I could connect to on the last firware. Changing the coexistence setting has no effect.
- PaiatzJul 04, 2017Guide
Thx for information... and now ? should this be corrected ? could i do a downgrade of the Firmware ??
- st_shawJul 05, 2017Master
You could download the older firmware to confirm it's an issue with the newer firmware. The latest firmware is 1.11.0.20.
The older version 1.10.1.2 is here: https://kb.netgear.com/000038700
But, if you downgrade the firmware it will automatically update shortly afterwards. So, you will need to wait for newer firmware and hope the issue is fixed.
It's probably a good idea to contact support and open a ticket to be sure they are aware of the issue.
