Paiatz
Jun 06, 2017Guide
Orbi WiFi System
Hello all, i have a ORBI RBK50 system and i want to connect Reolink Argus Wire-Free Cam´s to it. This Cameras are working only with 2.4 mHz. Why is this not possible ? regard R.Pojeti
- Jun 07, 2017
Try unchecking "Enable 20/40 MHz Coexistence" under Advanced, Advanced Setup, Wireless Settings, in the Orbi GUI.
There's a chance that might allow your 2.4 GHz device to connect.
Paiatz
Jul 04, 2017Guide
after electricity issue i lost the connection to my cam´s (2,4 GHz) i tryed to check and uncheck "Enable 20/40 MHz Coexistence" but nothing helps. the CAM´s are niot able to find the ORBI Wlan..any suggestions what i can do ??
st_shaw
Jul 07, 2017Master
Paiatz I was mistaken about not being able to connect to my old 2.4 GHz device. It turns out I can connect to it after all. The IP address of the device had changed. It was hard to detect this because Orbi never shows this device in the connected device list for some reason.
So, perhaps your cameras are connecting, and just had their IP address change.
