LSL9919
Aug 12, 2017Initiate
Orbi WiFi System
If it's possible to change orbi wifi 2.4 and 5 Ghz signal strength?
gimpyahern
Aug 20, 2017Aspirant
I have just purchased the Orbi AC3000. I have Internet speeds up 150 – 160 Mb per second at the router. I have installed the orbi router and satellite correctly. I have an old house of 2009 ft.². I am getting reasonable coverage tho not as good as advertised.
I am getting very good Wi-Fi signal in most places around the house.
However, it takes 30 to 45 seconds buffering to link to a normal News app, like sky News. Indeed, it fails to link up to the Irish National News app. Similarly, trying to access weather apps, they take ages to load up.
If I am listening to radio on my iPhone six, if I try and look up another website, while listening, the radio signal drops, and comes back when I exists the other website.
I just find that it takes ages for things to load up, but that once on the signal is solid and consistent. The Wi-Fi signal shows 50 Mb per second download near the satellite, but the drops away to under 20 at the furthest end.
Has anyone any similar problems, and any solutions. I tried to contact net gear support but I find it extremely difficult
peteytesting
Aug 20, 2017Hero
so you have a 2000 f sq house which tbh isnt that big and should be able to be covered by the orbi router its self without the sat
so in such a small area if your wifi is struggling then the building materials and or enviornmental conditions are coming into play and effecting the signal , so whats the house made of material wise internal walls wise and where is the orbi router and sat located
how far apart have you got the orbi router and sat apart and what do you mean by you have installed them correctly
here i have a 3500 sq ft house and an orbi router and 1 sat cover it fine my second sat is almost too much
- gimpyahernAug 21, 2017AspirantIt's not the spread that's the problem. It's that to open a website Thales at least 30 seconds even beside the router or satellite. The speeds on a test are very fast tho yet again to start the speed test using ookla app takes ages also
- peteytestingAug 21, 2017Hero
this indicates you have a routing issue
- gimpyahernAug 21, 2017AspirantHave you any suggestions as to how to correct this
