Owner
Aug 14, 2017Follower
Orbi WiFi System
I have a interlogix ( in past named GE ) simon XTI home alarm system. The system is all wireless using 319.5 MHZ frequency so I need a netgear wifi router that will NOT interefere with this signal as it will then set off a false alarm . This can be very inconvenient as it leads to wasted trips back to the building to check for breakin ins and then resetting the alarm. Which model is best for this problem?
1 Reply
- Retired_Member
