Jasonnkh
Aug 07, 2018Aspirant
Orbi WiFi System
Hi All, I am interested in buying netgear orbi wifi system to install in my new house in singapore a hdb 4 room flat with a 93 square feet, there are different model and type. Need some advise like...
- Aug 07, 2018
For that kind of size of home, a single router only or a Orbi router only should be sufficient:
https://www.netgear.com/support/product/orbi.aspx
The main router base can cover up to around 2000sq feet by itself, depending upon building matierals.
Aug 07, 2018Guru - Experienced User
Jasonnkh
Hi Furry,
As what you suggest is using just one single orbi router is enough, i don't need any additional satellites correct?
Do i need to place the router at the center of the house or anywhere of the house corner to enjoy the full coverage?
