Billyh1980
Mar 31, 2019Follower
Orbi WiFi system
When signing into my orbi app it said password is Default but when I enter it keeps saying its incorrect
airwolf666
Mar 31, 2019Aspirant
I am having an issue logging into my orbi android app in that i insert the password which works and then it takes me to the next page and then before i can choose what to do, the app takes me back to the login page.
michaelkenward
Apr 01, 2019Guru - Experienced User
This does nto sound like the same question as the one from Billyh1980
As per the "rules" you would do better to start your own discussion, especially if you want the Netgear team to see your message.
