jcalarcon01
Aug 13, 2017Aspirant
ORBI wifi very slow
Hello, I have been using Orbi for quite a while. When using a wired network and based on my Internet link I am able to get a great download speed (230Mbps) however when I connect using my iPhone ...
jcalarcon01
Aug 18, 2017Aspirant
Hello, thanks for the suggestion, I tried to disable both and enable both.
When both are disabled the speedtest shows a slight improvement to 14 Mbps, but still not what I would expect.
When both are enabled speedtest shows 7 Mbps.
I also noticed that a dropcam and a nest thermostat keep being disconnected, even though the devices are a few feet away from the router. I am thinking that the router may have some sort of failure.
What do you suggest would be the next step? Thanks for your help on this matter.
Juan Carlos
DarrenM
Aug 21, 2017Sr. NETGEAR Moderator
Send me a PM with your name,email and phone number I want to get you in contact with support to work on the issue.
DarrenM
- jcalarcon01Oct 25, 2017Aspirant
Hi
After weeks of failed tests and troubleshooting, I got a new set of ORBI router + satellite. This solved the issue I was having. Ticket is closed now. Now the replacement router got it's latest firmware upgrade 2.0.0.74 and the problem is back. At this point I believe it was always an issue with the 2.0.0.x firmware that is buggy and unstable. I would like to downgrade the firmware to the previous version but I don't have access to those files. Is there a way you can help me to gain access to the support ticket again? (29031017) or allow me to contact support again?
Thanks
Juan Carlos
- st_shawOct 25, 2017Master
jcalarcon01 Go to the following webpage and you can download any of 13 earlier firmware versions all the way back to the initial release:
https://www.netgear.com/support/product/RBK50.aspx#download
