jcalarcon01
Aug 13, 2017Aspirant
ORBI wifi very slow
Hello, I have been using Orbi for quite a while. When using a wired network and based on my Internet link I am able to get a great download speed (230Mbps) however when I connect using my iPhone ...
linkwrt
Jan 23, 2018Guide
jcalarcon01 wrote:Hello,
I have been using Orbi for quite a while. When using a wired network and based on my Internet link I am able to get a great download speed (230Mbps) however when I connect using my iPhone 7, I can only get 6 to 10Mbps. I wonder if there is something I need to do to get the best speed on Wifi, I think this is too slow.
My setup is the following:
2.4GHz: Auto
5Ghz: 48
20/40 MHz Coexistence Enabled
VMM settings (disabled for both 2.4 and 5 Ghz)
CTS/RTS Threshold 2347 on both, 2.4 and 5 Ghz)
Implicit Beamforming enabled
MU-MIMO disabled.
Thanks for your help!
Juan Carlos
Maybe this helps you:
Name (SSID) yourname
Region United States
Channel 36(P)+40+44+48
Mode Up to 866.7 Mbps
2.4Ghz channel auto
5Ghz channel 36
WPA2-PSK [AES]
WMM enabled
20/40 Mhz Coexistence enabled
CTS/RTS 2347
Preamble automatic
Enable Daisy... checked
Beamforming -- enabled
MU-MIMO -enable
For me , this is working.
