missourigirl61
Sep 27, 2016Follower
Orbi wifi
I have satellite internet thru local company and only get 10 mb month. After I use that amount, my speed goes down to almost dial up until start of next month. Would the Orbi take up the slack and keep my speed up when the satellite drops?
1 Reply
hi
if your isp caps your internet speed because you have gone over the limit then thats it your capped , the orbi cant change that
your lan speeds shouldnt drop etherway , so internal LAN / WLAN streams should not be effected if your internet is capped
