BishopD
May 30, 2019Aspirant
Orbi Wifi
I have the base station and two satellites. I have noticed the remotes dont have lights on them after all is settled down. should there be a light on top? The reason I ask is I have Ring cameras an...
CrimpOn
May 30, 2019Guru - Experienced User
BishopD wrote:I have the base station and two satellites. I have noticed the remotes dont have lights on them after all is settled down. should there be a light on top?
No. After satellites fully connect to the router, there is no "ring light" at the top of the device. Nor is there any light at the top of the router.
- FURRYe38May 30, 2019Guru - Experienced User
There is a LED ring indicator at the top of the Orbi RBR. Thsi will be off when fully operational though.
