LRF
Jun 21, 2019Aspirant
Orbi Wifi
We have the Orbi Wifi running in our home, model RBR20 with 2 satellites. Everything works really well (streaming services, cell phones), except that my husband can't connect to WiFi using his brand ...
Jun 21, 2019Guru - Experienced User
If one laptop is working and the other isn't, it maybe the wireless adapter card in the one effected laptop...
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
