Pwhite858
Mar 17, 2021Aspirant
Orbi will not connect to internet.
I have internet access through my modem to my computer when not connected through the Orbi but no access when connected through the Orbi via ethernet. Initially I lost the wifi connection so I resta...
vajim
Mar 17, 2021Master
Pwhite858 wrote:I have internet access through my modem to my computer when not connected through the Orbi but no access when connected through the Orbi via ethernet. Initially I lost the wifi connection so I restarted the modem but no luck. After connecting the ethernet from my modem to my pc, I was able to re-establish internet connection by updating the ip address. I reconnected to the Orbi but see a flashing blue ring before it turns solid magenta.
what kind of modem do you have?
Pwhite858
Modem is
Hitron E31N2V2 from isp.
- vajimMar 17, 2021Master
Pwhite858 wrote:
Modem is
Hitron E31N2V2 from isp.I believe that modem will need to be configured to the bridge mode.
Has it ever worked?
- Pwhite858Mar 17, 2021AspirantIt was working fine until a couple of days ago. We lost internet connection and I had a difficult time reconnecting the orbi. I finally changed the ethernet cable to re-establish communications . But ran into the same issue last night.
