ChenIL
Aug 04, 2019Follower
Orbi Wired and wireless Ethernet connection
Hi all Befor I buy Orbi system I need to know that I buy the right equipment , At my Home ialready have Router, provide from my local ISP, this Router provide DHCP range IP and V-DSL2 connection to...
ekhalil
Aug 04, 2019Master
You need the Orbi Router, it’s the central control unit for the Orbi system, but you can set it to AP mode if you don’t want it to act as a Router and provide router functionality.
If only one AP is enough for you the Orbi Router is sll what you need. If you need more APs then you can add additional Satellites.
