Nathanial15's avatar
Nathanial15
Follower
Aug 29, 2018
Orbi Wired Backhall Satalite Ethernet Speeds
Hi,
I was wondering if I have my orbi base station wired to my orbi satalite and Wired Backhall configured. Does this mean that the Ethernet ports out of the back of the orbi will get Ethernet speeds like if I were to plug it into the orbi base station or would I get WiFi speeds.
This would mean the Ethernet ports on the orbi satalite would effectively act as a switch for wired connections.
Nathanial
1 Reply
  • FURRYe38's avatar
    You will be connected at ethernet speeds.
    Yes.
