LSStream
Sep 07, 2019Guide
Orbi wired backhaul configuration issue
I just got an Orbi RBK53 "kit" (includes one RBR50 router and two RBS50 satellites) and wanted to relate some of my experience to the community. My home configuration is Xfinity cable > Netgear CM115...
Sep 09, 2019Guru - Experienced User
LSStream
Sep 09, 2019Guide
Not sure what this link is supposed to be, but it takes me to an “Access Denied” page.
- FURRYe38Sep 09, 2019Guru - Experienced User
It was a link to your initial post that was a duplicate. I responded there and mentioned it in this link here. I guess someone removed your initial post by mistake.
Try connecting the RBS directly to the RBR or place the switch after the RBR and then connect the RBS to this switch.
