Sidd93
Sep 12, 2019Aspirant
ORBI Wired Backhaul not working
Hi everyone! Im a proud owner of a orbi RBK50 (53) System. I just moved to a news house so i had the opertunity to lay a wired backhaul network for my orbi system. Happy that i was ...but 1 of m...
Sep 12, 2019Guru - Experienced User
Have you swapped positions with RBS #1 with RBS#2?
What is the model# of the ethernet switch in the configuration.
Sounds like the #2 RBS is faulty and needs to be replaced. I would get it replaced or take the entire system back to place of purchase and get another. Inform the company you got the system from that the RBS is faulty so they can get it sent back to NG.
- Sidd93Sep 13, 2019Aspirant
I have tried a different orbi RBS50 from a friend.
But i still got the same problem.
I have connected RBS50-1 to RBS50-2. I think thats the problem.
If i connect the RBS50-1 and RBS50-2 directly to the switch it works. But i cannot use the RBS50-1 to connect to the RBS50-2 thru ethernet.- FURRYe38Sep 13, 2019Guru - Experienced User
So can you connect both RBS directly to the RBR?
I don't know if daisy chaining RBS to the back of another RBS with ethernet will work.
Both directly connected to the RBR should though.
Daisy chain is Disabled
If i connect the RBS both to the RBR it works fine.
So i think the setup must be then RBR Switch RBS50-1 and Switch RBS50-2
To Bad i cant use the RBS to connect a different RBS
