Sidd93
Sep 12, 2019Aspirant
ORBI Wired Backhaul not working
Hi everyone! Im a proud owner of a orbi RBK50 (53) System. I just moved to a news house so i had the opertunity to lay a wired backhaul network for my orbi system. Happy that i was ...but 1 of m...
Sidd93
Sep 29, 2019Aspirant
I found the problem.
It was a faulty powersuply so everytime I was testing the setup. I mixed use the power adapter from the different orbi.
So I did a test with the orbi and the power supply. And that was the problem. Thanks for the help.
ekhalil
Sep 29, 2019Master
Glad that you found the solution, but I'm curious to know what you mean by mixing between the power supply adapters? As far as I know the power supply adapters are the same for the Orbi Router as well as the Satellites, what have you mixed? :)
- Sidd93Sep 29, 2019AspirantHehe, I'm sorry I mean with mixed that the powersupply that came with the RBR and the RBS that I mixed those around. So I didn't keep track on the powersupply when ever I change the position of the RBR and RBS. So when I didn't change the power supply of the RBR and RBS I was seeing the pattern. So now I could conclude it was the power supply.
- ekhalilSep 29, 2019MasterThanks, so do you see that the power supply of the router has different specs than those for the satellite? Can you please please read the specs on these and list them here. It will be interesting to see this. Thank you.
