amrobx
Dec 27, 2017Guide
Orbi wired backhaul performance
Has anyone that isn’t experiencing issues gotten an idea of the performance gains, if any, with wired backhaul? Also, has netgear mentioned anything about opening up the 3rd high speed band to wirele...
amrobx
Dec 28, 2017Guide
Thanks for the response. If you don’t mind, was your homeplug gigabit or one of the 500-600 Mb models? I know even the gigabit model doesn't quite hit full speed, but it’s at least a reference point for me.
Dd852
Dec 28, 2017Luminary
Hi. Gigabit. The long story is that on some plugs I get very good throughout (800 mbps according to the tplink app) but as luck would have it where I wanted to put the orbi it dropped in half - must be a different sub circuit. And of course 400 isn’t 400 - it is shared up and down so it reduced the broadband to an effective 200 max.
