amrobx
Dec 28, 2017Guide
Orbi wired backhaul performance
Has anyone that isn’t experiencing issues gotten an idea of the performance gains, if any, with wired backhaul? Also, has netgear mentioned anything about opening up the 3rd high speed band to wirele...
Apr 09, 2018Guru - Experienced User
Ok, just making sure. Ya yours is a un-managed switch:
https://www.netgear.com/home/products/networking/switches/soho-ethernet-switches/GS308.aspx
Enjoy.
epsilonkore
Apr 09, 2018Apprentice
Right, no need for remote services, switch level qos, the power envelope or the size (that wouldnt fit in my small built in network/telco/coaxbox) that the Orbi doesnt already provide downstream. What was it that you were making sure of exactly?
