amrobx
Dec 28, 2017Guide
Orbi wired backhaul performance
Has anyone that isn’t experiencing issues gotten an idea of the performance gains, if any, with wired backhaul? Also, has netgear mentioned anything about opening up the 3rd high speed band to wirele...
Apr 09, 2018Guru - Experienced User
Making sure you did have a managed switch, if you did, would have to ask how you were making it work. LOL. Seen issues with other posters having issues with manages switches. I presume there is some switch configurations that could make them work with the Orbi system. Just know know what that would be. I have two swtiches in between my router and satellite. Working well. Non managed of course.
dalnew
Apr 09, 2018Tutor
I was running some ethernet backhaul tests the other day and am seeing something a bit weird. When I connect my laptop to either orbi satellite via the the ethernet ports i see around 940Mbps. When I connect my laptop to the ethernet port of the orbi router, however, I get around 740Mbps. When I bypass the orbi router and connect it directly to the switch via the same cable its back to 940 Mbps. Any idea why the orbi router would degrade the performance so much?
I'm using FW 2.1.3.4 on all the Orbis and I have a netgear GS308 as my switch that all the orbis are connected to.
- epsilonkoreApr 09, 2018Apprentice
That is strange, when you upgraded to 2.1.3.4 did you do a full wipe with the reset pin or just an upgrade? I have (in a seperate elaborate thread) experienced odd performance issues out of the routers ports when upgrading to newer firmwares. At one point I was locked around 500Mbps from the router, but my (then wireless) ports on my satellites would give me over 800Mbps... wireless was FASTER than my routers ports! I ended up downgrading to the original firmware (yes the oldest one out there) on router and satellites, i then wiped them using the reset pin, and upgraded to the last of the 1.x firmwares, repeated the reset with pin again, then moved to the 2.x firmwares... my routers switch suddenly went back to full speed. I have seen this happen many times on older routers when I put WRT or Tomato firmwares on them, sometimes to get performance back I had to go to the oldest original firmwares the router supported to restore all functionality, then upgrade back to the current.
That being said, FIRST I would check to be sure your ethernet cable isnt the issue, swap it and retest... sometimes the simplest thing is the source of your problem.
- dalnewApr 09, 2018Tutor
I tested the ethernet cable definitely not that. When I plug directly into the cable the Orbi router is using I get 940Mbps. When I plug my other cable into the satellites I get 940Mbps. When I plug that same cable into the back of the Orbi router 700Mbps.
I did full resets of all the Orbis when flashing them with the latest firmware.
- FURRYe38Apr 09, 2018Guru - Experienced User
How long are you waiting to speed test after you plug back into the router a 2nd time? Seems like it's working on 1st test however when you come back around, it's lower speeds. Wondering if there is some latent process in the system thats not being cleared in a period of time from when you 1st test to 2nd test. Does this happen if you come at a later time frame or day later?
dalnew wrote:I tested the ethernet cable definitely not that. When I plug directly into the cable the Orbi router is using I get 940Mbps. When I plug my other cable into the satellites I get 940Mbps. When I plug that same cable into the back of the Orbi router 700Mbps.
I've tested it multiple times throughout the day. It's always consistantly 200+Mbps lower than if I plug directly into the switch or another Orbi.
Ok. Does it happen with a different PC or laptop? Just seeing if this tracks to other wired PCs as well. Is odd.
