amrobx
Dec 28, 2017Guide
Orbi wired backhaul performance
Has anyone that isn’t experiencing issues gotten an idea of the performance gains, if any, with wired backhaul? Also, has netgear mentioned anything about opening up the 3rd high speed band to wirele...
dalnew
Apr 09, 2018Tutor
I've tested it multiple times throughout the day. It's always consistantly 200+Mbps lower than if I plug directly into the switch or another Orbi.
Apr 09, 2018Guru - Experienced User
Ok. Does it happen with a different PC or laptop? Just seeing if this tracks to other wired PCs as well. Is odd.
