Bib8050
May 13, 2020Tutor
Orbi Wired connection drops
I have a C7000v2 connected to RBR50v2 with 1 satelite running wirelessly, I have two GS608 switches as well. Everything on the wired network is Cat6 and my trunk lines are Cat7 from the modem to RB...
May 13, 2020Guru - Experienced User
Bib8050 wrote:
I have the C7000 setup in bridge mode and I have disabled the wifi on it and I have the RBR in APmode.
If you have the C7000 in bridge mode then you need to set the RBR to router mode.
- Bib8050May 13, 2020Tutor
I am resetting that now. I thought I read somewhere that it needed to be in AP mode. its been running off and on half working for two weeks in AP mode where it works fine and then drops... Just put it into router mode and will see what happens.
- FURRYe38May 13, 2020Guru - Experienced User
AP mode if you leave the C modem in router mode. If the modem is in modem only mode, then the RBR needs to be in router mode. The network needs a DHCP server enabled either on the modem or on the RBR to work right.
I have reset the RBR into router mode, not sure where I read it needed to be in AP mode. super irritating, also realized the stock cable that came with the RBR was cat 5 so I swapped that as well. everything appears to be working, I have been pulling my hair out for two weeks trying to figure out why wifi is working fine and wired is dropping, freezing etc constantly. Thank you for the help!!
