Bib8050's avatar
Bib8050
Tutor
May 13, 2020
Orbi Wired connection drops
I have a C7000v2 connected to RBR50v2 with  1 satelite running wirelessly, I have two GS608 switches as well.  Everything on the wired network is Cat6 and my trunk lines are Cat7 from the modem to RB...
  • FURRYe38's avatar
    May 13, 2020
    Bib8050 wrote:
    I have the C7000 setup in bridge mode and I have disabled the wifi on it and I have the RBR in APmode.
    If you have the C7000 in bridge mode then you need to set the RBR to router mode.
