ThatOneDude
Jun 28, 2020Aspirant
Orbi wired connection to sattelite wanlan conflict
A few days back, I had to reset our router because the internet was acting weird. I have a modem/router provided by Comcast (Cisco DPC3941T). Ever since then, on one computer, I am repeatedly getting...
Jun 29, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
When you set bridge mode, did you reconfigure router mode on the RBR?
What is the default IP address of the ISP modem when in router mode? 192.168.1.1 by chance?
ThatOneDude wrote:A few days back, I had to reset our router because the internet was acting weird. I have a modem/router provided by Comcast (Cisco DPC3941T). Ever since then, on one computer, I am repeatedly getting a BRS_wanlan_conflict error whenever I try to connect to a webpage that is not https. This computer is connected to the Orbi sattelite (RBS20) via ethernet. No other computers in the home are wired into either the sattelite or the router (Orbi RBR20) itself. None of them are getting the same issue, either. I have tried switching the Comcast router to bridge mode, but that did not solve the issue. What else might be happening?
