ThatOneDude
Jun 28, 2020Aspirant
Orbi wired connection to sattelite wanlan conflict
A few days back, I had to reset our router because the internet was acting weird. I have a modem/router provided by Comcast (Cisco DPC3941T). Ever since then, on one computer, I am repeatedly getting...
ThatOneDude
Jul 01, 2020Aspirant
A factory reset has not been done yet. I did reconfigure the router settings for the Orbi when the modem was in bridge more. And the defaukt IP is not 192.168.1.1
Jul 01, 2020Guru - Experienced User
Are you sure the modem is fully bridged? If it is, the WAN port IP address on the RBR will be a ##.##.###.### kind of address, not a 192 or 172 or a 10 IP address.
Try a full on reset and setup from scratch on the Orbi if you know for sure the modem is fully bridged.
What is the LAN side IP address for the RBR now?
