uhhu
Aug 28, 2020Aspirant
Orbi Wireless Access Point
Hello - i see other threads with similar questions, but as they are solved, i cannot ask for additional information.
I have an Orbi RBR50, RBS50, 2x RBW30 in my house, and have black spots in several areas. Every wall in the house is made of brick, and as its not open plan; there is a lot of wall getting in the way of the satellites. My understanding from the equipment is that I have 8,000 sq ft of Wifi coverage in my 5,000 sq ft home.
When I installed the Orbi, I set my existing Virgin Media Hub3 to modem modem mode and my Orbi router as the router. These are in the same room, connected by a LAN cable. I then have my satellites dotted around the place. The two wall satellies are showing as green for signal. If I move them, I create bigger black spots. For example, one is in a hall which serves the hall and half of two rooms. The RBS50 is orange. However, when it is in the green spot, I create more black spots in high use areas.
This isn't giving me the coverage I need, so I think I am going to need to wire the house (something I desperately want to avoid given the walls are brick), buy more RBS50 and wire them in. However, this means the RBW30 will no longer be supported and may not work, and I may not have solved my black spot issues.
I have looked at Wireless Access Points, with the thought that I could buy a couple, and attach to the ceilings upstairs and connect them back to the router. But having read on this forum, that will not give me a full mesh like I have now with Orbi?
On the forum, I see people mention that they turn their router into an AP. Will this give me any benefit for coverage?
Do I have other options?
If I am going to go to the bother of wiring the whole house, would I be best to buy several wireless access points and move away from using the Orbi?
- MstrbigMasterYour best option, if you do not want to wire is add more RBS50 satellites. Your RBW30 units are fine, but don't offer the coverage that RBS50 does. The 50 series Orbi is a powerful system with a strong and fast backhaul offering far superior coverage.
Just my opinion based on similar installs.- uhhuAspirant
Looking online, it is difficult to find the satellites at a good price. Can I use the router as a satellite to another router? For example, I can buy a router and satellite for £300, whereas two satellites will cost me £400.
If i bought a 2nd router and satellite, can that router connect to my existing router as a satellite?
- MstrbigMaster
uhhu wrote:Looking online, it is difficult to find the satellites at a good price. Can I use the router as a satellite to another router? For example, I can buy a router and satellite for £300, whereas two satellites will cost me £400.
No a router cannot be used as a satellite.
Some have spoken about a hack to turn it into a satellite, but if it bricks the device, it's not worth it.
