RichWilson
Nov 22, 2020Tutor
Orbi Wireless devices, can not see wired devices - but can ping.
I have the RBR50v2 in AP Mode, with 3 satelites. (latest firmware) I have a Ubiquity EdgeMax 12 router, with the following settings. (latest firmware) I have a "wired resources" network as 192...
Nov 23, 2020Guru - Experienced User
What happens if you put the Orbi system on the same IP address network as the wired network?
What FW version are you using?
RichWilson
Nov 23, 2020Tutor
When I plug into my "wired devices" network as 192.168.3.0/24, I get an IP address on that network, and the functionality is the same (not working correctly).
- FURRYe38Nov 23, 2020Guru - Experienced User
Seems like something may not be configured on the router. Orbi when in AP mode would not be blocking anything. However most configuration are using the same IP address submet while in AP mode with the RBR.
