horbath
Nov 09, 2017Aspirant
Orbi with apple TV horribly slow
Hello I'm using Orbi at home. Several devices are hooked up to it (Sonos, iPhone, iPad, PC's) and all work fine. I have gigabit fiber so speeds are ok. However I bought an Apple TV 4th gen redentl...
Wizec
Nov 09, 2017Apprentice
Check your connected devices page and if the Apple TV is connected on the 2.4Ghz band, try lowering the power for 2.4Ghz on the Advanced Wireless Settings page to 25%
horbath
Nov 12, 2017Aspirant
Ok, I tried. Did not work out at all :( everything is the same as before. The only remedy is router reboot.
