TMAN1988
Mar 11, 2020Aspirant
Orbi with At&t Fiber 1000
Hey everyone, I've been experiencing my internet going out mutliple times a day. My setup is Arris BGW210 Gateway with Orbi AX6000 set as a router. I have ip passthrough with all firewall setting...
TMAN1988
I'm not real sure. I was told i needed to turn firewall off on gateway for the ip passthrough to work properly. Was told that the firewall on the orbi is automaticly on when installed. Does this sound right?
Mar 11, 2020Guru - Experienced User
Well if it's in IP pass thru, Firewall on the ARRIS modem wouldn't matter as the pass thru isn't effected by the firewall. However, this is correct.
One thing you can do is set the RBR up for AP mode. Remove the IP pass thru configuration from the ARRID modem and enable the firewall on the modem/router and see if anything changes. If the ONT and modem still experience RED indications, then this is still an ISP issue that they needs to look at. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- TMAN1988Mar 11, 2020Aspirant
Thanks for your help. I set the Orbi in AP Mode about a week ago and it still continues to go out. I switched it back to router mode in order to get the benifits that the RBK852 offers. I've called At&t and a tech is coming out Saturday. I've been dealing with this for two weeks now and ready to get it fixed!
- FURRYe38Mar 11, 2020Guru - Experienced User
Ya, the ISP needs to have a look. Once they can clear it on there side then Orbi should be good, router or AP mode.
- Jramirez730Aug 04, 2020Aspirant
So whatever happened? Was it an AT&T thing or an Orbi thing?
- FURRYe38Aug 04, 2020Guru - Experienced User
What are you having problems with?
What Orbi model do you have?
Jramirez730 wrote:So whatever happened? Was it an AT&T thing or an Orbi thing?
