Joshiajay
May 17, 2017Aspirant
Orbi with ATT Fiber
I'm trying to set up my new att fiber connection with my Orbi router. I get good speeds from speed test if it connects but often get webpages hanging up when loading. Netflix takes forever to start. ...
- May 18, 2017
I have ATT Fiber also. Best option is to turn your ATT Fiber Router into bridge mode and leave your Orbi in it's default router mode. I think there were some other issues with the router ATT supplied me but I can't remember off the top of my head. I think it had a built-in firewall that I turned off or something. It had nothing to do with Netflix or other issues you are reporting though. I think it had to do with my IP cameras. After you reconfigure your ATT router then I would suggest you make sure the Orbi has the latest firmware then factory-default the Orbi settings.
gfrey
May 18, 2017Apprentice
