Joshiajay
May 17, 2017Aspirant
Orbi with ATT Fiber
I'm trying to set up my new att fiber connection with my Orbi router. I get good speeds from speed test if it connects but often get webpages hanging up when loading. Netflix takes forever to start. ...
- May 18, 2017
I have ATT Fiber also. Best option is to turn your ATT Fiber Router into bridge mode and leave your Orbi in it's default router mode. I think there were some other issues with the router ATT supplied me but I can't remember off the top of my head. I think it had a built-in firewall that I turned off or something. It had nothing to do with Netflix or other issues you are reporting though. I think it had to do with my IP cameras. After you reconfigure your ATT router then I would suggest you make sure the Orbi has the latest firmware then factory-default the Orbi settings.
Joshiajay
May 18, 2017Aspirant
Grey, Did you figure out the settings yourself or did someone from att help you?
- gfreyMay 19, 2017Apprentice
I did it myself. My Router had Wifi builtin so I had to login to disable all of that crap. Login stuff was on the bottom of the router. Just needed to hook my laptop up to the Ethernet jack on the back.
