jsmith1234768
Dec 27, 2016Follower
Orbi with Century Link and Netgear Modem Broadband High-Speed DSL Modem DM200
I will be getting Century Link Service for Internet and have the Orbi Router. Will the Netgear Modem Broadband High-Speed DSL Modem DM200 work with the Orbi and Century Link Service?
Does dish have DSL or Cable and which modem should I buy if I stay with Dish?
- Hydro130Luminary
That DM200 modem should work fine with your new Century Link service (assuming it is DSL service) and your Orbi.
Once your CenturyLink Installation is done (including the modem setup), then just connect the Orbi's router unit to the new modem using an ethernet cable, and follow the instructions for setting up the Orbi.
As far as I know, Dish is satellite-based internet, so it is neither cable nor DSL - I am not familiar with what modems are compatible with that type of service. If that's the service you have now and you decide to keep it, there shouldn't be a need to get a new modem - you should be able to contnue using what you have now.
- netwrksMaster
Hydro130 wrote:That DM200 modem should work fine with your new Century Link service (assuming it is DSL service) and your Orbi.
Before you buy any modem, make sure the modem you want to buy, is supported by your ISP. If you do not know, contact your ISP..
