Davapersson
Nov 21, 2017Guide
Orbi with EX8000 – AC3000 Nighthawk X6S Extender - wired backhaul
Is it possible to have EX8000 – AC3000 Nighthawk X6S Tri Band WiFi Range Extender in AP-mode, hardwire it with Ethernet to Orbi Router RBK50 ? I think I finally have a (fake?) wired backhaul, or am I...
DarrenM
Nov 22, 2017Sr. NETGEAR Moderator
Yes it should work as a wired AP are you wanting to do this because orbi does not have Ethernet backhaul?
DarrrenM
- DavaperssonNov 22, 2017Guide
Thnx for quick reply Darren.
Yes, exactly. I heard that Orbi Satellite maybe will have this wired feature in the future also, but no timeline for this has been communated so far.
When u are here, do u know if the Nighthawk Extender use all six antennes for wifi when it is on Ethernet to router? And if Orbi Satellite will use six antennas (all bandwith) for wifi if it has an Ethernet backhaul.
/David
(pardon my bad English, from Sweden :))
