Supermansings
Jun 15, 2020Follower
Orbi with fiber, outdoor extensions
Hi all. I recently converted to Smithville fiber internet. It comes with what they call a gigacenter, which is where the fiber plugs in and also acts as the WI-FI router. It is certainly fast, but my ...
Jun 15, 2020Guru - Experienced User
If the ISP router can be removed and use the Orbis router then this would be preferred. Something to ask the ISP about.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
