Supermansings
Jun 15, 2020Follower
Orbi with fiber, outdoor extensions
Hi all. I recently converted to Smithville fiber internet. It comes with what they call a gigacenter, which is where the fiber plugs in and also acts as the WI-FI router. It is certainly fast, but my ...
CrimpOn
Jun 15, 2020Guru - Experienced User
Supermansings wrote:
Will the fiber go into the orbi?
No. Orbi must connect with an ethernet cable. There is no fiber input capability. The "ideal" solution is to place the Gigacenter into "bridge" or "passthrough" mode. You can see if that is possible by connecting to the Gigacenter web interface (http://192.168.1.1) using the user name and password printed on the product label. Search through the menus to see if there an option. Or, call the nice Smithville tech support line and ask them how to do it.
- CrimpOnJun 15, 2020Guru - Experienced User
If this is the product: https://www.searanchconnect.org/pdf/Calix_844G_UG.pdf
then I did not find an option to put the Gigacenter into bridge mode.
There IS an option to disable the WiFi on this Gigacenter.
So, the most obvious solution is to put the Orbi into access point mode and continue to use the Gigacenter to administer IP addresses, perform port forwarding (if needed), etc.
