Kulpdogg
Dec 15, 2017Guide
Orbi with fios
Hello, Have Orbi system with FIOS Gigabit. Current issue is I'm only getting half speed (Between 400-550 usually) rather than true gigabit. I have tried running though the Verizon router in both rou...
MKCD44
Apr 03, 2018Aspirant
Uggggghh! I just returned my Velop today for the Orbi since most things I read online had Orbi listed higher due to features like USB port and being able to run a VPN... and now my speeds are less than 1/2 what I had on Velop. I even preferred their app (which was listed in a lot of “cons” sections). I really don’t want to go back to the store to exchange it back out...
Apr 03, 2018Guru - Experienced User
Whats speeds are you referring too?
What is your ISP speeds UP and Down you pay for?
Speed testing wireless or wired. Wired is preferred mainly for speed testing.
What ISP mfr and model# modem are you using?
What FW are you using?
- MKCD44Apr 03, 2018AspirantUpload / download speeds. I have FiOS gig speed internet using their Quantum Gateway router (WiFi turned off). I was using the speed test in the app. Verizon FiOS app shows I’m getting over 900 mbps both up and down. For WiFi... Linksys app showed 300-600 down and 800+ up constantly. NG app shows 80-200 down and 400-600 up. A few times down hit over 400 and up to over 800, but it’s inconsistent.
- FURRYe38Apr 03, 2018Guru - Experienced User
Is the router enabled on this ONT? If so, you might want to set up the DMZ on the ONT for the Orbi router if your using the Orbi router in router mode.
Speeds may vary depending upon client device HW and design. Some devicies, you may only see 400-500Mb max on wifi speeds. Wired ethernet should be consistently 900+-Mb.
