timc166293
Jan 21, 2019Aspirant
Orbi with fios
I have Fios. When using their router I get 900Mbs both directions.
When using Orbi I get about 500 down and near 900 up.
Why the big difference?
Thanks!
ekhalil
Jan 22, 2019Master
Thanks!
- What speed do you get when you do the Orbi built-in Speed Test?
- Did you have any other wired devices connected to Orbi when you did the speed test from the PC?
- Do you have wired backhaul to a satellite?
- timc166293Jan 22, 2019AspirantYes from router
No just single PC
Fiber- ekhalilJan 23, 2019Master
timc166293 wrote:
Yes from router
No just single PC
FiberThanks, my questions were as follows:
- What speed do you get when you do the Orbi built-in Speed Test that you can find here in the web GUI:
You can also find the same testing in the Orbi phone app.
- Did you have any other wired devices connected to Orbi when you did the speed test from the PC? Anything else connected to the LAN ports in the router or the satellite?
- Do you have wired backhaul to a satellite? Is the router connected to the satellite(s) using Ethernet cable or wireless?
Thank you
- timc166293Jan 23, 2019Aspirant
Yes Web GUI and through orbi app and speedtest.net. All consistent.
Test when no traffic but see 60 devices or so connected; sonos, PC, iphones, TVs, etc.
All remotes are wireless, but we are testing from orbi router up-stream. I am confused why this question matters.
Thanks!
