ShaunML09
Aug 17, 2019Aspirant
Orbi with GS728TPP (Smart Managed Switch)
I have an Orbi and have issues with the ethernet connections - wireless works fine (most of the time). Setup is Modem -> Orbi -> GS728TPP -> computer. I have been having significant issues where th...
Aug 17, 2019Guru - Experienced User
Is the RBS connected to the switch?
ShaunML09 wrote:I have an Orbi and have issues with the ethernet connections - wireless works fine (most of the time). Setup is Modem -> Orbi -> GS728TPP -> computer. I have been having significant issues where the wired connection hangs 40-60% of the time when surfing the internet and sometimes times out. It will then start working again after 2-3 seconds but the constant hanging is getting annoying.
Reading here it seems like managed switches is not preferrable but I needed a POE switch. I put the switch in "switch" mode but doesn't seem to have helped.
Can anybody advise what I need to do for settings?
ShaunML09
Aug 18, 2019Aspirant
Router Firmware = V2.3.5.30
Switch = 6.0.1.24
Internet is through Fiber Optic with a company called Summit Broadband. The interior "modem" is by IPhotonix and the outside "box" is by Photonix as well - I don't have specific information on the models. The internet itself works well on wireless, its just the wired connections that are the problems.
The Orbi is connected to the Switch with ethernet cable.
- FURRYe38Aug 18, 2019Guru - Experienced User
Is the switch connected between the RBR and RBS? Or is the RBS directly connected to the RBR?
Check into the switches management UI to see if there is any IGMP protocols in the switch. Disable them ALL. Orbi has known issues with switches running IGMP and Green Ethernet features.
Try the Orbi sytem in AP mode as a test....
