Vqmpire
Nov 07, 2023Aspirant
Orbi with Hive hub for central heating blocking ports
Have Orbi RBR50, Satellites, and hive hub connected by ethernet. The hive I can see connected to Orbi has ip address but it is not able to communicate with the hive internet servers. So as the h...
CrimpOn
Nov 14, 2023Guru - Experienced User
Can you confirm that this is the product:
https://www.hivehome.com/shop/connectivity/hive-hub
It is very unusual for Internet of Things (IoT) devices to require that the user "open ports" from the internet to the customer LAN. Most devices establish connections from themselves TO support servers on the internet. Orbi does not block outbound connections. (God only knows what Armor and Smart Parental Controls (SPC) do, and she's "not telling".)
Are Armor or SPC enabled on this system?
For example, almost every device will make connections to learn the current time using the Network Time Protocol (UDP port 123). These connections are always "out" and it would make zero sense to forward port 123 from the internet to some specific device on the LAN.
Likewise, devices often establish https connections to support servers (port 443).
When you follow the directions on this page, Hive 'app' never shows the hub connecting?
https://community.hivehome.com/s/article/What-to-do-if-your-Hive-Hub-is-offline
- VqmpireNov 15, 2023Aspirant
It's Hive Nano 2 hub, pictures below (just disconnected for photo).
Not using Orbi Armour (Not Activated), PArental Controlls (Not Enabled) or Access controlls.
Tried the page but no luck. Always top led flashing...
- CrimpOnNov 15, 2023Guru - Experienced User
(I have zero experience with PPoE.)
Which Ethernet port is the hub connected to?
Is there a switch between the Orbi and the Hive hub?
Green LED flashing quickly or slowly?
- schumakuNov 15, 2023Guru - Experienced User
Internet-(Data-)traffic is on it's own dedicated VLAN.
On carrier operated CPEs are using the VoIP and IPTV VLANs independent, and doing smart NAT to allow typical home LAN access for IPTV-boxes. VoIP is typically not user accessible, as the users have no access to the naked VoIP to connect user supplied VoIP or SIP phone stations.
As we're talking about a plain simple Orbi - not knowing about this ISP environment anyways - it won't take care about these 8-). All it could do is fan-out these two VLANs (== bridge) to a dedicated local network port where the user could connect e.g. a set-top box.
Not the first and and the last provider where the support people have no clue what they talk about ... happened several times here with misleading or false information ref. service access vs. port forwarding already.
Connected this IoT wonder to a port defined as bridged to the ISP VLAN (VoIP or IPTV) by error?
