Vqmpire
Nov 07, 2023Aspirant
Orbi with Hive hub for central heating blocking ports
Have Orbi RBR50, Satellites, and hive hub connected by ethernet. The hive I can see connected to Orbi has ip address but it is not able to communicate with the hive internet servers. So as the h...
schumaku
Nov 15, 2023Guru - Experienced User
The examples showing e.g. only 2.4G or 5G Wi-Fi as a destination are not that common. Typically, one does use a defined port or two for a dedicated Ethernet connection (or two).
Vqmpire
Nov 16, 2023Aspirant
Have VLAN set-up when moved to new ISP as below
Internet Service Provider: PPPoE
ROUTER INFORMATION
Hardware Version RBR50
Firmware Version V2.7.5.4
GUI Language Version V1.0.0.423
Operation Mode Router
LAN Port
MAC Address 08:02:8E:A7:43:44
IP Address 192.168.0.1
DHCP Server On
IP Subnet Mask 255.255.255.0
INTERNET PORT
IP Address xx.xx.xx.xx
Connection PPPoE
IP Subnet Mask 255.255.255.255
Domain Name Server 8.8.8.8 and 1.1.1.1
