Vqmpire
Nov 07, 2023Aspirant
Orbi with Hive hub for central heating blocking ports
Have Orbi RBR50, Satellites, and hive hub connected by ethernet. The hive I can see connected to Orbi has ip address but it is not able to communicate with the hive internet servers. So as the h...
CrimpOn
Nov 16, 2023Guru - Experienced User
I'm just really confused. Ports 2 and 3 have nothing connected so their VLAN setting would seem to be not relevant.
Port 1 has a VLAN of 911, except that it is not enabled.
(once again my ignorance is obvious.... why Netgear chose to identify Ethernet ports as LAN1, LAN2, LAN3 in the Show Statistics box, but the VLAN settings refer to Port1, Port2, Port3. Does "LAN" mean the same thing as "Port"?)
Shouldn't the VL:AN setting on Port 1 be enabled?
