momor77
Sep 02, 2016Follower
Orbi with ISP gateway
I've looked up other thread on using Orbi with ISP gateway as AP modem. My question is, if I set the Orbi router in AP mode (assuming LAN to LAN connection to gatway with router function), will the ...
mdgm-ntgr
Sep 02, 2016NETGEAR Employee Retired
Yes. The seamless roaming will still work with the Orbi router in AP mode.
We'd suggest disabling Wi-Fi on the modem/gateway, and using the Orbi router and Satellite to provide all the Wi-Fi for your home.
