otabrab
Dec 08, 2020Aspirant
Orbi with Metronet 1gig fiber
Hi, I've recently switched from cable internet 400mb to metronet fiber 1gig internet. With the cable i was getting consistent speeds above 380mb throughout my house and over 400mb 20 feet from main ...
vajim
Dec 08, 2020Master
tell us about your modem...before and after metronet fiber
- otabrabDec 08, 2020Aspirant
The original modem just says Spectrum on it and PC20 along with serial numbers etc. The Metronet modem is much smaller and looks like it says Nokia and in another spot says Intertek. Don't rerally see any other badging at all except for a Metronet label.
- vajimDec 09, 2020Master
Did you ask your new (?) ISP how the Orbi should be configured?
- otabrabDec 09, 2020Aspirant
The tech said i would probably have to ask Orbi as the use Eero pro 6 for their routers
- michaelkenwardDec 09, 2020Guru - Experienced User
I assume that you fibre use an "ONT" rather than a modem to get you the Internet. So just a box with an Ethernet socket.
I'm not familiar with genuine fibre Internet, I should be so lucky. But past experience suggests that any change of the Internet service requites a reset of the local network equipment. This wipes out any settings inherited from the previous Internet service.
So have you reset the RBR50 and set it up again from scratch?
