missmary
Jul 03, 2019Aspirant
Orbi with satellite won't connect after a long power outage
My power was out for 24 hours. I finally have wifi back, but I can't connect my Orbi router. I've tried rebooting. Unplugging it and rebooting, following the suggestions of the app, and everything el...
CrimpOn
Jul 03, 2019Guru - Experienced User
From Netgear's web page explaining Orbi color codes, it appears that the Orbi is unable to connect to the modem:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
Have you tried restarting the modem?
Do you have a wired PC or Mac (desktop, laptop with ethernet port) that can be connected directly to the modem? (i.e. unplug the Orbi and plug the computer directly into the port where the Orbi was connected.)
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
missmary wrote:
My power was out for 24 hours. I finally have wifi back, but I can't connect my Orbi router. I've tried rebooting. Unplugging it and rebooting, following the suggestions of the app, and everything else I've read. Costco won't take it back because it's a year old. Can someone please explain (in plain english...I'm old!) how to reconnect it? The LED ring stays a constant magenta. It says it's a model RBR40. Thank you!
- missmaryJul 03, 2019Aspirant
I have no idea how to answer all of that. I can tell you everything was working perfectly before the power went out (we were struck by lightening but have a whole house surge protector and every other piece of electronics and appliance is working fine). Now, I just can't get it to reestablish a connection. I tried to download a software update, but it doesn't seem to work. I don't have any idea how to find the other information mentioned.
- FURRYe38Jul 03, 2019Guru - Experienced User
You might have someone help you with that information.
Try a factory rest on the RBR and RBS and setup from scratch. IF this fails to connect the RBS, then the RBS could be damaged.
