Aronius
Mar 23, 2019Tutor
Orbi with Sky Q
Hi, I installed my Orbi’s the other day , all devices are getting a strong stable wireless connection except the Sky Q’s. Connecting them to the orbi network (my virgin hub is in modem mode) is ok...
SimonGT007
May 18, 2019Guide
Hi Aronius - not sure if you managed to resolve your Sky Q issues, but there is another factor at play that could be impacting both your Sky Q TV streaming (which uses Sky's on mesh network in 5GHZ) and your Orbi's wifi performance. Unfortunately both devices hog the 36-48 5GHZ channels as they use an 80MHZ channel width (so even if the Sky and Orbi are on different channels in the set up, this is just the center channel and they use the other 3 channels around it). Doubled up with the fact that the 5GHZ channels 36-48 are already getting very congested in the UK , especially in urban areas like London, leads to lots of interferance (e.g. where I live I can pick up at least 10 other wifi networks in my house and a few of them are similar strength signals to my Orbi and Sky networks). The only thing I've found that can help is to try the following:
1. If possible place you Orbi some distance away from your Sky TV main box (not easy I know if your broadband is from Virgin as likely the cable comes in near where your TV is).
2. Force the Sky Q system to use a narrow 40GHZ band using the 'engineers menu' options on your main Sky box. To get to this scroll to the "Settings" menu and before selecting it type in 001 on the remote and then hit the select button. You should see a message pop up at the top of the screen warning you are in the advanced menu. Goto "Network" and you should see an option "5GHZ wifi channel width'. You now have two options, and will need to experiment to work out which one is best for you as it will depend on other wifi networks in your area (if you have a wifi scanner like WiFI explorer of inSSIDer that should make things easier to work out which is best combition for you):
(a) Set the Sky Q to 40 MHZ/Ch.36 and set your Orbi to channel 48
OR
(b) Set the Sky Q to 40 MHZ/Ch 44 and set your Orbi to channel 36
If you do this on the main box it should cascade this setting around any other Sky Q TV boxes in the house, but you can double check by going into the same menu on the other boxes. There is more on this issue at https://www.expertreviews.co.uk/tvs-entertainment/pvrs/1404726/how-to-fix-sky-q-connectivity-problems/page/0/3
I found this had no impact at all on my Sky Q performance as 40MHZ is more than enough bandwidth for streaming TV, even 4K HDR.
3. Final option only works if you don't use Sky broadband and have your main Sky Q box connected via ethernet to your network. You can use the same menu options as per point 2 above and disable the 2.4GHZ wifi on your Sky Q mesh network as it's not needed and will reduce congestion on the 2.4GHZ band in your home.
Unfortunately the ideal solution would get either Sky or Netgear to make additional 5GHZ channels available. I've been lobbying Netgear for over a year on this point (see https://community.netgear.com/t5/Idea-Exchange-For-Home/Please-provide-more-5GHZ-wifi-channel-options-restricting-to/idc-p/1752699#M2362) so please like this post if you would like to see this feature and add in some supporting comments as the more customers that ask for it should increase the chances of it being added. You can do the same with Sky forumns.
There is also one more advanced thing you can do and seperate the 5GHZ and 2.4GHZ wifi networks on your Orbi, so you can make sure your high performance devices always make use of the 5GHZ channel. Because of the interfereance from Sky Q I found that my iphone and other devices would keep on connecting to the 2.4GHZ channels even when there was a reasonable 5GHZ signal and the only way to force the iphones to use the right channel was to resort to this option. I as have Virgin Vivid 350Mbs that was the only way I could get the full speed on wifi networks - I can only get 30-40Mbs on a strong 2.4GHZ connection so was losing c90% of the speed. Doing this is not something Orbi offically recommend but it can be done, so only do this if you are happy to give it a go. You always revert back if needed. See this thread for full details on how to do this https://community.netgear.com/t5/Orbi/How-to-set-a-separate-SSID-for-the-5-GHz-network-on-your-Orbi/td-p/1396594
The other option of last resort is to use powerline adapters or ethernet cables for your Sky Q boxes and disable the Sky mesh network completely and use the advance menus in Sky discussed above to turn off both 2.4ghz and 5ghz wifi radios. You will have to reset all the network settings on your Sky system if you go this route.
Hope this helps!
- AroniusOct 08, 2019TutorHi,
Since this thread , I've actually had 2 sky engineers out to try and fix this but each one has not been successful. To get you back to speed...
I have the top Virgin package for broadband , the Virgin hub is in modem mode and connected to a Tri Band AC3000 Netgear Orbi router. The router is also connected to a RBS50 Orbi satallite. I also have a Sky Q silver box which is directly wired (via Ethernet) to the Orbi Satellite, the Satellite has a dedicated 5GHz band to communicate back to the orbi router via channel 108.
I also have a Sky Q mini which is connected via Ethernet to a unmanaged switch, the switch is then connected to the Orbi router directly. The switch also connects to a TV and Xbox which works outstandingly. And finally, I have another Sky mini which has no Ethernet connection and therefore operates on WiFi.
I started having problems when the Orbi mesh and Sky Mesh was clashing... so I changed the Orbi 5GHz channel to 48 and the Sky 5GHz channel to 40MHz ch36. Although they still clash this improved my 5GHz speeds on WiFI.
Now here is the strange bit:
When I go to the Orbi app and the network devices map all my Sky Q devices show as a wired connection to the main Orbi router. This is of course wrong as the main Sky Q box is connected via Ethernet to the satellite and one of the Sky Q's isn't even connected via Ethernet!
Any ideas? As sometimes the box's flip out and many times programs show up with black pictures and internet options don't work like sky cinema etc.
I am going wire all my Sky Q products to the Orbi’s (Sky q main would be connected to the satellite, and the minis to the main router). Would this fix the problems I’m having? As it’s been going on for a while and is a real pain lol!
Thanks!- FURRYe38Oct 08, 2019Guru - Experienced User
Aronius wrote:
Hi,
The RBS does not communicate with the RBR wirelessly when the RBS is ethernet connected to the RBR. It now communicates with the RBR via ethernet wire.
Both RBR and RBS needs to be connected to the same switch. What is the mfr and model# of this un-managed switch?Disable Daisy Chain on the RBR.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
The Orbi system is meant to be the only wifi system with in the home. Having other wifi signal in close proximity as you can see, causes problems. Try the Orbi system with the ISP wifi turned OFF.
This is normal for when the RBS and other devcies are connected via ethernet, even though they are wirelessly connected to the RBS, the end point data flow ends up on the wired ethernet connection to the RBR which sees this as a wired connection, not wireless.
Simplify your configuration and try the Orbi system wifi as a stand alone wifi system and turn OFF your other wifi radios on the Sky Q devcies. Your surroundings are noisey with having too much wifi going on.- AroniusOct 08, 2019TutorThankyou for the detailed reply! :)
When I said “The router is also connected to a RBS50 Orbi satellite .” ... I meant that it is wirelessly connected, there is no Ethernet connection between the Orbi router and the satellite. With this is mind should I still disable the ‘daisy chain’ on the RBR?
Why do the satellite and router both need to be connected to this switch? It is a 5 port TP Link switch (see attached) which had a Xbox, tv and Sky Q mini wired to the switch, the switch is then wired to the orbi router. I didn’t think this had anything to do with the satellite?
And I don’t deliberately have 2 WiFi systems in my house, I have the Orbi WiFi and my Sky Q WiFi, and the Sky Q main box communicates with my two sky minis via 5GHz/2.4ghz WiFi. Many people must have the Orbi system and Sky TV in the same house but I can’t find the problem I’m having anywhere else.
What do you mean by your last point? I am going to try to wire my last sky mini to the Orbi router so all my Sky Q products are wired and then I can disable the WiFi on the sky boxes, is this okay?
