Aronius
Jan 31, 2020Tutor
Orbi with Sky Q
Hi,
My ISP is Virgin media, 350 package. I have one tri-band orbi router and one orbi satellite.
For a while I had problems with the Sky Q mesh interferring with the Orbi 5GHz,
This was finally solved after drilling holes into the wall... my main Sky Q 2TB box is etherneted to the Orbi sateliite. A sky q mini is etherneted to the Orbi router, and another mini is etherneted to a unmanaged switch, then to the router,
Everthing works, but not to a high standard. There is a lot of 'please wait' between menus which shouldn't really happen. However my main problem is both the main sky q box and both minis do not show all of the preview pictures for shows. This is very annoying! Please see the pictures via the link attached.
Info on the problem + ping test
I have done a ping test and all devices communicate back excpect the Sky Q's. There is a screenshot of this on the google drive files (the first 3 ping tests are of the sky q's).
I have done the usual turn everything off and on routine and set the DMZ as the Sky Q, did not make a difference.
I had a chat with the Sky community first and they reviewed the info and suggested some kind of setting need's changing on the Orbi... Sky community chat
Anyone got any ideas?
