LaaseJ
Mar 05, 2017Aspirant
Orbi with Technicolor tg799vac
Hi, I live in Sweden and have fiber via internet supplier Telia. Telia have their own modem/router (all in one unit, at least I think so?) called Technicolor TG799VAC. Can I use the Orbi system? I ...
- Mar 06, 2017
LaaseJ wrote:Thank's but st_shaw answer that I need to turn of the wifi radio to use the Orbi as acces point. But you mean that this is not neccessary?
Best regards
Lasse
No. Bing-Stroller has his router in "bridge" mode, as I described.
Bing-Stroller
Mar 05, 2017Luminary
I have an all in one modem router supplied by Virgin Media.
I turned off the router side and it effectively becomes modem only.
I was then able to plug the Orbi in to work as the router.
