LaaseJ
Mar 05, 2017Aspirant
Orbi with Technicolor tg799vac
Hi, I live in Sweden and have fiber via internet supplier Telia. Telia have their own modem/router (all in one unit, at least I think so?) called Technicolor TG799VAC. Can I use the Orbi system? I ...
- Mar 06, 2017
LaaseJ wrote:Thank's but st_shaw answer that I need to turn of the wifi radio to use the Orbi as acces point. But you mean that this is not neccessary?
Best regards
Lasse
No. Bing-Stroller has his router in "bridge" mode, as I described.
loomis1975
Mar 05, 2017Luminary
If you setup the Orbi in Access Point mode, you can connect it to any LAN port on your modem/router. And keep your existing routing setup without changes.
LaaseJ
Best regards
Lasse
- st_shawMar 06, 2017Master
Best regards
Lasse
